Migrating Classic WebSpeed project in a new PAS OE Web App project
maretix
Hi to all.
I use v10.2b and i wrote int he past little oe project with Webspeed.
This project contains 10 cgi wrappers that get parameters , read data using an Unix appserver and create xml responses.
We installed in a test server v11.7 and new application server PAS OE ...
I created a new Web App project and i am trying to study how to rewrite and migrate 'old' project in new one.
For example.
V11b Web App project has a main web handler class.
Do i need to create 10 web handlers (one for each old cgi wrapper) or 1 web handler that handles all business logic of old 10 cgi wrappers ...(example with a complex case that understand http request ...)
I'd like to start good to write new PAS OE web app programs.
I'd like and i think it is the reccomended scenario to use web hanlders.
I read about PAS OE and some artcicles about web handler ,,
Unfortunately My doubts still remain...
I am very confused ...
Can anyone send me any 'real' examples about this issue ???
Examples source and url to invoke.
PS. I can send me to my old project..
Regards thanks in advance.
peterjudge
You can migrate "classic" webspeed to PASOE using the (shipped) CompatibilityHander. In the development server it's the default handler - so in a dev environment you can test easily.
If you want to write new code then you need to add your own WebHandlers. You can use them to process/handler a (small?) part of your application and have the rest still flow through the classic webspeed code.
ForEachInvoiceDelete
Active Member
Make sure you're using compatibility handler.
If you try and use the standard web-handler you will spend a decent amount of time trying to figure out why web-context wont work and rewriting functions like "get-field".
