redsuitee
I need some helps here..
I want to make a communication between 2 programs, let say from Progress 9 to Progress 10..
this is my code in Progress 9 .
test.p is a program in Progress 10 version.
How can I display Variable A in test.p? Is it possible?
Thank you in advance.
DEFINE STREAM s1.
DEF VAR A AS CHAR INITIAL '123456789'.
INPUT-OUTPUT STREAM s1 THROUGH
VALUE("C:\OpenEdge\bin\prowin32.exe
-p test.p")
NO-MAP NO-CONVERT UNBUFFERED.
PUT STREAM s1 A.
INPUT-OUTPUT STREAM s1 CLOSE.
