Hi folks.
Is there any sort of index statistics in a Progress database? Somthing like: table customer has 4 indexes. 70% of all searches are done by using index 1. the other 3 were each used in 10% of the queries.
I know that the compiler determines which index is used and that I can look it up using the xref-option at compile time. But this only documents the static queries which are getting less and less...
Another thing is the "USE-INDEX" option. I know it's bad with a Progress database in the background - but what about Oracle or MS-Sql dataserver. It seems that the compiler doesn't save/generate which index needs to be used for a query. Any thoughts on this?
