Hyphen (-) issue with SQL92
osmjimtsr
Dear all,
Currently I have an issue with Hyphen-ed Table/Field name.
With SQL89 we can use the -esqlnopad.
With SQL92 we can add \ or "" on the Table Name or Field.
My Problem:
There are too many of field/table name need to be prefixed with "\" or
enclosed with " ".
Is there any solution like the SQL89's -esqlnopad ?
Thank you.
Regards,
joey.jeremiah
ProgressTalk Moderator
Staff member
Not that it's really relevant to the original question but a common best practice is to use underscores as word separators with database fields.
Because reserved words use hyphens, never underscores and even a single underscore guarantees there will never be reserved word conflicts.
osmjimtsr
You must be kiddin', right?
I know we can use unix' - SED to search and replace,
but is there any other solution than this one?
Any Progress personnel info on this?
Thank you.
Regards,
tamhas
No, I'm not kidding. This is a place where historical practice in naming standard for Progress databases comes into ugly conflict with naming standards in SQL. I don't think there is a magic bullet. Choices are:
1) Get used to adding the quotes ... doesn't mean you can't build a tool to help put them in for you in legacy code, but one way or another they need to get there.
2) Define a bunch of views which don't have this problem and use those instead. Of course, if you have a bunch of legacy SQL, that needs to be fixed to point at the views.
3) Do a name refactoring on your database to get rid of the problem. I suggest ProRefactor to do this. I think it is the best solution long term, although it tends to mean a fair amount of short term work.
osmjimtsr
Thanks a lot Tamhas,
I think you had saved my time of searching for a magic bullet.
I understand now that by using SQL92 we need to
remove this "road block".
You know sometimes the "fair amount of short-term work" needed to do this necessary things, does not easily translated to the approval
of your boss :confused: hehehehe.
I will try to look at the prorefactor and see how best it can help.
Really appreciated.
Regards,
