Our company recently upgraded from 10.0B to 11.1. In 10.0B I used the following code to create new records in the database:
I'm hoping someone can shed light on the code required for 11.1. I'm not the author of the code above and thus far I have been able to convert most of my other snippets to work with 11.1 but the keyindex fields for ICSP and ICSW have eluded me thus far. Can anyone shed some light or loan me their magic decoder ring?
Thanks,
Larry
PROCEDURE AddProd:
DEFINE INPUT PARAMETER aprod LIKE icsp.prod.
DEFINE INPUT PARAMETER adescrip1 LIKE icsp.descrip[1].
DEFINE INPUT PARAMETER adescrip2 LIKE icsp.descrip[2].
DEFINE INPUT PARAMETER adescrip3 LIKE icsp.user10.
DEFINE INPUT PARAMETER alookupnm LIKE icsp.lookupnm.
DEFINE INPUT PARAMETER aunitsell LIKE icsp.unitsell.
DEFINE INPUT PARAMETER astempart LIKE icsp.user3.
DEFINE INPUT PARAMETER acatpart LIKE icsp.user4.
DEFINE INPUT PARAMETER asupplier LIKE icsp.user5.
DEFINE INPUT PARAMETER akittype LIKE icsp.kittype.
DEFINE INPUT PARAMETER akitroll LIKE icsp.kitrollty.
DEFINE INPUT PARAMETER abodxfer LIKE icsp.bodtransferty.
DEFINE INPUT PARAMETER atiecomp LIKE icsp.tiedcompprt.
DEFINE INPUT PARAMETER strProdCat LIKE icsp.prodcat.
DEFINE INPUT PARAMETER statustype LIKE icsp.statustype.
DEFINE VARIABLE strKeyIndex AS CHARACTER NO-UNDO.
DEFINE VARIABLE n AS INTEGER INITIAL 1 NO-UNDO.
DEFINE VARIABLE i AS INTEGER NO-UNDO.
ASSIGN i = LENGTH(aprod).
If i >= 9 then
assign i = 9.
Do While n <= i:
assign strKeyIndex = strKeyIndex + "p" + string(n) + "_" + substring(replace(replace(aprod,"-","_"),"/","_"),n,1,"CHARACTER") + " ".
n = n + 1.
end.
CREATE ICSP.
ASSIGN icsp.prod = aprod
icsp.descrip[1] = adescrip1
icsp.descrip[2] = adescrip2
icsp.user10 = adescrip3
icsp.lookupnm = aprod
icsp.lookupnm = alookupnm
icsp.unitsell = aunitsell
icsp.unitstock = aunitsell
icsp.unitcnt = aunitsell
icsp.prodcat = strProdCat
icsp.kittype = akittype
icsp.kitrollty = akitroll
icsp.bodtransferty = abodxfer
icsp.tiedcompprt = atiecomp
icsp.cono = 1
icsp.enterdt = today
icsp.statustype = statustype
icsp.user3 = astempart
icsp.user4 = acatpart
icsp.user5 = asupplier
icsp.priceonty = "L"
icsp.ICSPECRECNO = 1
icsp.keyindex = "sxcono_1 sxkt_ sxpcat_" + strProdCat + " sxlkup_" + replace(replace(aprod,"-","_"),"/","_") +
" sxprod_" + replace(replace(aprod,"-","_"),"/","_") + " " + replace(replace(aprod,"-","_"),"/","_") + " " + strKeyIndex + " " + replace(replace(aprod,"-","_"),"/","_") + " " +
strProdCat + " " + replace(replace(replace(adescrip1,"/","_"),",","_"),"-","_") +
replace(replace(replace(adescrip2,"/","_"),",","_"),"-","_") + " ".
if akittype = "b" then
assign icsp.exponinvfl = yes.
Thanks,
Larry
