James Palmer
As far as I know you should be able to run 32bit rcode on a 64bit client, and vice versa. The only issues you may face are when you use things like OCXs as 32bit versions of these won't work on 64bit machines AFAIK. So compiling might become an issue on the 64bit server. But judging by the fact you already have a mix of clients you probably already have this in hand. Someone more experienced/clever is probably going to come along and blow all my comments apart shortly, but I thought I'd post anyway
