L
Libor Laubacher
Firstly - I have flagged your posts as spam/abuse. The last 3 threads you created that is. Secondly - the URL from James Palmer works just fine and points to the very first thread you created, which I believe you know quite well. You just decided to ignore it. Now to your "question" - what do YOU think the activities are and should be? Why don't YOU try to play with promon and come up with what YOU think is important and then it can be discussed and explained here. Thanks.
