awadheshmca12
Hi Libor, the current permission to the log is 644 but it failed to write to that log. -rw-r--r-- 1 abc xyz 4840 Jun 30 11:24 /test/apps/tomcat/temp/exceptions.log The startup.sh is run by abc only the owner. The owner only starts it. OS: OS Version: Red Hat Enterprise Linux Server release 5.10 (Tikanga) Java: /usr/java/jdk1.5.0_21/bin/java java version "1.5.0_21" Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_21-b01) Java HotSpot(TM) 64-Bit Server VM (build 1.5.0_21-b01, mixed mode) Progress:OpenEdge Release 10.2B04 DLC: /test/apps/dlc WRKDIR: /test/apps/dlcwrk OEM: /test/apps/oemgmt OEMWRKDIR: /test/apps/wrk_oemgmt Let us know if you need more info. Regards, Awadhesh
