ske
Hi, In Arcade Showroom, I tried running the pre-installed virtual machine with OpenEdge 11.4, and then tried doing a couple of things in the stand-alone AppBuilder and also in the AppBuilder perspective in Developer Studio, but I had some problems in this version, as compared to the machines for previous versions in Arcade Showroom, for instance 11.3. In this version, I could no longer find the standard OCX controls CSSPin and CSComboBox in the AppBuilder object palette. Only PSTimer. Where did the other two go? The 11.4 documentation still says they should be there, and in 11.3 they are. In the stand-alone AppBuilder (only), when I open some random non-visual procedure file, usually AppBuilder opens a window with a treeview of the code sections in that file, in addition to the procedure editor window. But in this version, the section window doesn't show anything, it is just all grey background. Why? I tried creating a new SmartWindow, and then selected adding a general SmartObject, and then browsed to C:\Progress\OpenEdge\gui\src\adm2\dyntreeview.w to add this as the SmartObject. That works in previous versions, but here I get a dialog showing me error 6087 about some referenced OCX not being available. Why? (This was tested two weeks ago. I tried asking through other channels in the meantime, without answer.)
