Surasak
I'm having some problems about crystal report component: PrintControl.dll which come from Crystal Report XI R2. Symptom: I migrate application that create by Progress 9.1B to OE 11.4. This application running in XP and use Cystl32.OCX (come from Crystal Report 8.0). I modify this application with OE App Builder 11.4 (x86) in Windows 7 (x64). The problem occur when I drop Print Control component into smart window then App Builder is crash. The error in windows application event are below: Faulting application name: prowin32.exe, version: 11.4.0.1294, time stamp: 0x53d2e691 Faulting module name: PrintControl.dll, version: 11.5.0.313, time stamp: 0x437a109b Exception code: 0xc0000005 Fault offset: 0x00003040 Faulting process id: 0x538 Faulting application start time: 0x01cffb27cc46c702 Faulting application path: C:\OE114\OpenEdge\bin\prowin32.exe Faulting module path: C:\Program Files (x86)\Business Objects\Common\3.5\crystalreportviewers115\ActiveXControls\PrintControl.dll Report Id: 13ff3e94-671b-11e4-adb9-b482fe527a6a Note: 1. I try modify application within OE 11.4 (x64) but face problem similar above. 2. I try manual register all dll file in PrintControl,cab into c:\winodws\SysWow64 directory but face problem similar above. 3. I try use Print Control component that come from CR 2008 SP4 but face problem similar above. I'm waiting for any suggestion and comment. Thanks.
