I
ithrees
Hi All, Is there anybody successfully integrated and used the NFC plugin with the rollbase mobile? I am currently trying this, but getting error when build the android apk. Thanks in advance, Ithrees. Log says: Started by user jboss Building remotely on android-slave in workspace /srv/appery/jenkins/root/workspace/22546-android Deleting project workspace... [copy-to-slave] Copying '2429/22546/android/**/*', excluding nothing, from 'file:/srv/appery/temp/build_temp/' on the master to 'file:/srv/appery/jenkins/root/workspace/22546-android/' on 'android-slave'. [22546-android] $ /bin/sh -xe /tmp/hudson6601715374383203142.sh [22546-android] $ /bin/sh -xe /tmp/hudson4757217907385406606.sh Extracting sources from archive You have reached a restricted system for the use of authorized users only. Individuals using this computer system without authority or in excess of their authority are subject to having all their activities on this system monitored and recorded by system personnel. Anyone using this system expressly consents to such monitoring and is advised that if such monitoring reveals possible evidence of criminal activity system personal may provide the evidence of such monitoring to the appropriate authorities. + mvn clean package [INFO] Scanning for projects... [INFO] ------------------------------------------------------------------------ [INFO] Reactor Build Order: [INFO] [INFO] PlugIn_Test-parent [INFO] barcode scanner [INFO] PlugIn_Test [INFO] [INFO] ------------------------------------------------------------------------ [INFO] Building PlugIn_Test-parent 1.1-parent [INFO] ------------------------------------------------------------------------ [INFO] [INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ PlugIn_Test-parent --- [INFO] [INFO] ------------------------------------------------------------------------ [INFO] Building barcode scanner 1.0 [INFO] ------------------------------------------------------------------------ [INFO] [INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ BarcodeScanner --- [INFO] [INFO] --- android-maven-plugin:3.6.1:generate-sources (default-generate-sources) @ BarcodeScanner --- [INFO] ANDROID-904-002: Found aidl files: Count = 0 [INFO] ANDROID-904-002: Found aidl files: Count = 0 [INFO] Manifest merging disabled. Using project manifest only [INFO] /srv/app/asdk/build-tools/19.1.0/aapt [package, --non-constant-id, -m, -J, /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/target/generated-sources/r, -M, /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/AndroidManifest.xml, -S, /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/res, --auto-add-overlay, -A, /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/assets, -I, /srv/app/asdk/platforms/android-10/android.jar] [INFO] [INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ BarcodeScanner --- [INFO] Using 'UTF-8' encoding to copy filtered resources. [INFO] skip non existing resourceDirectory /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/src/main/resources [INFO] skip non existing resourceDirectory /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/target/generated-sources/extracted-dependencies/src/main/resources [INFO] [INFO] --- maven-compiler-plugin:3.1:compile (default-compile) @ BarcodeScanner --- [INFO] Changes detected - recompiling the module! [INFO] Compiling 239 source files to /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/target/classes [WARNING] /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/src/com/google/zxing/client/android/share/ShareActivity.java: Some input files use or override a deprecated API. [WARNING] /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/src/com/google/zxing/client/android/share/ShareActivity.java: Recompile with -Xlint:deprecation for details. [WARNING] /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/src/com/google/zxing/BarcodeFormat.java: Some input files use unchecked or unsafe operations. [WARNING] /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/src/com/google/zxing/BarcodeFormat.java: Recompile with -Xlint:unchecked for details. [INFO] [INFO] --- android-maven-plugin:3.6.1roguard (default-proguard) @ BarcodeScanner --- [INFO] [INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ BarcodeScanner --- [INFO] Using 'UTF-8' encoding to copy filtered resources. [INFO] skip non existing resourceDirectory /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/src/test/resources [INFO] [INFO] --- maven-compiler-plugin:3.1:testCompile (default-testCompile) @ BarcodeScanner --- [INFO] No sources to compile [INFO] [INFO] --- maven-surefire-plugin:2.17:test (default-test) @ BarcodeScanner --- [INFO] No tests to run. [INFO] [INFO] --- maven-jar-plugin:2.5:jar (default-jar) @ BarcodeScanner --- [INFO] Building jar: /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/target/BarcodeScanner-1.0.jar [INFO] [INFO] --- android-maven-plugin:3.6.1:apklib (default-apklib) @ BarcodeScanner --- [INFO] /srv/app/asdk/build-tools/19.1.0/aapt [package, -f, -M, /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/AndroidManifest.xml, -S, /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/res, --auto-add-overlay, -A, /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/assets, -I, /srv/app/asdk/platforms/android-10/android.jar, -F, /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/target/BarcodeScanner-1.0.ap_] [INFO] /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/libs does not exist, looking for libraries in target directory. [INFO] Building jar: /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/target/BarcodeScanner-1.0.apklib [INFO] [INFO] ------------------------------------------------------------------------ [INFO] Building PlugIn_Test 1.1 [INFO] ------------------------------------------------------------------------ [WARNING] The POM for org.apache.cordova:cordova:jar:3.5.1 is missing, no dependency information available [INFO] [INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ PlugIn_Test --- [INFO] [INFO] --- android-maven-plugin:3.6.1:generate-sources (default-generate-sources) @ PlugIn_Test --- [DEBUG] Expanding: /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/BarcodeScanner/target/BarcodeScanner-1.0.apklib into /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/target/unpack/apklibs/phonegap.plugins_BarcodeScanner_apklib_1.0 [DEBUG] expand complete [INFO] ANDROID-904-002: Found aidl files: Count = 0 [INFO] ANDROID-904-002: Found aidl files: Count = 0 [INFO] ANDROID-904-002: Found aidl files: Count = 0 [INFO] Manifest merging disabled. Using project manifest only [INFO] /srv/app/asdk/build-tools/19.1.0/aapt [package, -m, -J, /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/target/generated-sources/r, -M, /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/AndroidManifest.xml, -S, /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/res, -S, /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/target/unpack/apklibs/phonegap.plugins_BarcodeScanner_apklib_1.0/res, --auto-add-overlay, -A, /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/assets, -I, /srv/app/asdk/platforms/android-14/android.jar] [INFO] /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/res/xml/config.xml:30: error: Error parsing XML: not well-formed (invalid token) [ERROR] Error when generating sources. org.apache.maven.plugin.MojoExecutionException: at com.jayway.maven.plugins.android.phase01generatesources.GenerateSourcesMojo.generateR(GenerateSourcesMojo.java:493) at com.jayway.maven.plugins.android.phase01generatesources.GenerateSourcesMojo.execute(GenerateSourcesMojo.java:204) at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59) at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183) at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156) at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537) at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196) at org.apache.maven.cli.MavenCli.main(MavenCli.java:141) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230) at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409) at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352) Caused by: com.jayway.maven.plugins.android.ExecutionException: ANDROID-040-001: Could not execute: Command = /bin/sh -c cd /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test && /srv/app/asdk/build-tools/19.1.0/aapt package -m -J /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/target/generated-sources/r -M /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/AndroidManifest.xml -S /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/res -S /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/target/unpack/apklibs/phonegap.plugins_BarcodeScanner_apklib_1.0/res --auto-add-overlay -A /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/assets -I /srv/app/asdk/platforms/android-14/android.jar, Result = 1 at com.jayway.maven.plugins.android.CommandExecutor$Factory$DefaultCommandExecutor.executeCommand(CommandExecutor.java:246) at com.jayway.maven.plugins.android.phase01generatesources.GenerateSourcesMojo.generateR(GenerateSourcesMojo.java:489) ... 22 more [INFO] ------------------------------------------------------------------------ [INFO] Reactor Summary: [INFO] [INFO] PlugIn_Test-parent ................................ SUCCESS [0.263s] [INFO] barcode scanner ................................... SUCCESS [28.086s] [INFO] PlugIn_Test ....................................... FAILURE [0.988s] [INFO] ------------------------------------------------------------------------ [INFO] BUILD FAILURE [INFO] ------------------------------------------------------------------------ [INFO] Total time: 34.426s [INFO] Finished at: Tue Nov 11 06:28:49 UTC 2014 [INFO] Final Memory: 20M/96M [INFO] ------------------------------------------------------------------------ [ERROR] Failed to execute goal com.jayway.maven.plugins.android.generation2:android-maven-plugin:3.6.1:generate-sources (default-generate-sources) on project PlugIn_Test: MojoExecutionException: ANDROID-040-001: Could not execute: Command = /bin/sh -c cd /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test && /srv/app/asdk/build-tools/19.1.0/aapt package -m -J /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/target/generated-sources/r -M /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/AndroidManifest.xml -S /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/res -S /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/target/unpack/apklibs/phonegap.plugins_BarcodeScanner_apklib_1.0/res --auto-add-overlay -A /srv/appery/jenkins/root/workspace/22546-android/2429/22546/android/PlugIn_Test/assets -I /srv/app/asdk/platforms/android-14/android.jar, Result = 1 - [Help 1] [ERROR] [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch. [ERROR] Re-run Maven using the -X switch to enable full debug logging. [ERROR] [ERROR] For more information about the errors and possible solutions, please read the following articles: [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException [ERROR] [ERROR] After correcting the problems, you can resume the build with the command [ERROR] mvn goals -rf lugIn_Test Build step 'Execute shell' marked build as failure Deleting project workspace... done Finished: FAILURE
