Please excuse my ignorance in regards to nomenclature here, I am brand new to Progress.
I need to pull some data from a progress database (Openedge 10.2) in which the table is storing Binary image files and move it into a SQL . The files are split off into multiple chuncks. From what I have learned in the original GUI they are pulled out of the database and then reconstructed using a "PUT" function in the original interface.
I have been provided this data in a sql table that is designed as such:
Table name ImageTable
file_id (int)
file_seq (int)
file_data (varbinary(max)
There are multiple file_id's, these are then sorted by the file_seq, the file_data holds the chuncks of the image.
12345, 1, chunk
12345, 2, chunck
12345, 3, chunck
I need to concatentate the binary chuncks into a single chunck and then move it into a separate table with the file_id column of 12345 and the combined chuncks creating the entire binary (jpg's).
file_id (int)
file_seq (int)
12345, 1, chunk
12345, 2, chunck
12345, 3, chunck
