Xavi_qsoft
Good morning.
I am currently migrating an application from the 9.1D version of progress towards v10.2A.
I find the following problem or question.
I converted the database, from 91d to the 10.2a, until here everything ok.
Applications. W run successfully.
But I find that if the .w are not compiled, the first time I try to run it takes 5 seconds to receive the form, the second time it runs successfully in 1 second, why? this is not happening in the versn 91d
I also discovered that if the .w is compiled with .r this problem is not exist, the first time application runs correctly in 1 second.
Thanks.
Thanks.
