Cecil
Hi All
I have a crude way of appending data to an existing defined sized MEMPTR by swapping and resizing MEMPTRs. I feel its a bit of a hack without having to dump a MEMPTR to disk and reloading each time.
Is there are better/elligent way of appending data to a MEMPTR?
DEFINE VARIABLE mpDataTemp AS MEMPTR NO-UNDO.
DEFINE VARIABLE mpDataTarget AS MEMPTR NO-UNDO.
DEFINE VARIABLE mpDataSwap AS MEMPTR NO-UNDO.
SET-SIZE(mpDataSwap) = 0.
SET-SIZE(mpDataSwap) = GET-SIZE(mpDataTarget) + GET-SIZE(mpDataTemp).
COPY-LOB FROM OBJECT mpDataTarget TO OBJECT mpDataSwap OVERLAY AT 1.
COPY-LOB FROM OBJECT mpDataTemp TO OBJECT mpDataSwap OVERLAY AT GET-SIZE(mpDataTarget) + 1.
SET-SIZE(mpDataTarget) = 0
SET-SIZE(mpDataTarget) = GET-SIZE(mpDataSwap).
COPY-LOB FROM OBJECT mpDataSwap TO OBJECT mpDataTarget.
SET-SIZE(mpDataTemp) = 0.
/** mpDataTarget has now been resized with the new data being appended to it. **/
