What Is High Water Mark How We Check In Aspect Of Performance Issue
Mike
Moderator
what is high water mark how we check in aspect of performance issue?
Database version number: 1174
Database state: Open (1)
Database damaged flags: None (0)
Integrity flags: Executing with -r (0)
Database block size (bytes): 1024
Total number of database blocks: 1417
Database blocks high water mark: 1375
Free blocks below high water mark: 116
Record blocks with free space: 3
Before image block size (bytes): 8192
Before-image cluster size (kb): 512
After image block size (bytes): 8192
Last transaction number: 169
Highest file number defined: 0
Database create (multi-volume): 03/25/04 16:05
Most recent database open: 06/04/04 14:19
Previous database open: 06/04/04 14:19
Local Schema cache time stamp: 03/24/04 20:47
Most recent .bi file open: 06/04/04 14:20
RETURN - show remaining, U - continue uninterrupted, Q - quit:
Previous .bi file open: - -
Time since last truncate bi: 0 (seconds)
Most recent full backup: 05/26/04 15:06
Database changed since backup: Yes
Most recent incremental backup: - -
Sequence of last incremental: 0
RETURN - repeat, U - continue uninterrupted, Q - quit
how we check performance ? High water mark here?? how please give me description of all fileds?
please help
regards Shane
Cringer
ProgressTalk.com Moderator
Staff member
A high water mark is the highest level that that metric has been at since the last DB restart. So in the case of database blocks.
That's how many are available.
That's how many were in use at the point of the highest usage.
I would suggest you attend some training or hire a consultant. Your issues are a lot more fundamental than can be covered on this forum.
