That you solved the problem using RELEASE doesn't mean that RELEASE was the right way to solve the problem. Chances are that correct scoping would also have solved the problem.
Maintenance on an obsolete application it is not as you write new code and have understanding of the whole bl and record scoping of a procedure. Thus if it works there is no need to fix it(maybe a hot patch).
