pkcitstaff
Trying to connect through ODBC to a view I created in Progress. The view was created to rename some columns that have hyphens / dashes.
The view is called NODASH and through procedure editor I can query it "SELECT fax_num FROM NODASH" works fine.
But from SQL Explorer or an ODBC connection I get an error on a similar "SELECT fax_num FROM PUB.NODASH"
The error is Table/View/Synonym not found (7519)
Am I querying the view incorrectly?
Thanks for any help.
