Using EnumPrintersA on 64 bit
okion
Hi there,
Progress does have an example "How to use the EnumPrintersA".
When I run it on 32 bit in works fine.
But when I run it on 64 bit I get an error.
I get an error : Put/Get functions not allowed on uninitialized memory. (2914)
Does anyone know how to get it working on a 64 bit progress installation.
Here is the example:
/* DEFINE the widget handle for the window */
DEFINE VARIABLE C-Win AS WIDGET-HANDLE NO-UNDO.
/* Definitions of the field level widgets */
DEFINE BUTTON cmdFind
LABEL "&Find"
SIZE 15 BY 1.14.
DEFINE VARIABLE lstPrinter AS CHARACTER
VIEW-AS SELECTION-LIST SINGLE SCROLLBAR-VERTICAL
SIZE 54 BY 8.57
FGCOLOR 1 FONT 6 NO-UNDO.
/* ************************ Definitions ************************ */
PROCEDURE EnumPrintersA EXTERNAL "winspool.drv":
DEFINE RETURN PARAMETER res AS LONG.
DEFINE INPUT PARAMETER flags AS LONG.
DEFINE INPUT PARAMETER name AS CHARACTER.
DEFINE INPUT PARAMETER Level AS LONG.
DEFINE INPUT-OUTPUT PARAMETER pPrinterEnum AS MEMPTR.
DEFINE INPUT PARAMETER cdBuf AS LONG.
DEFINE OUTPUT PARAMETER pcbNeeded AS LONG.
DEFINE OUTPUT PARAMETER pcReturned AS LONG.
END PROCEDURE.
/* ********************** Frame Definitions ********************* */
DEFINE FRAME frmMain
lstPrinter AT ROW 1.95 COL 4 NO-LABEL
cmdFind AT ROW 11 COL 43
WITH 1 DOWN NO-BOX KEEP-TAB-ORDER OVERLAY
SIDE-LABELS NO-UNDERLINE THREE-D
AT COL 1 ROW 1
SIZE 62 BY 11.62.
/* ******************** Triggers ********************************/
ON CHOOSE OF cmdFind IN FRAME frmMain /* Find */
DO:
DEFINE VARIABLE pPrinterInfo AS MEMPTR NO-UNDO.
DEFINE VARIABLE lpPrinterName AS MEMPTR NO-UNDO.
DEFINE VARIABLE pPrinterEnum AS MEMPTR NO-UNDO.
DEFINE VARIABLE i AS INTEGER NO-UNDO.
DEFINE VARIABLE res AS INTEGER NO-UNDO.
DEFINE VARIABLE pcbNeeded AS INTEGER NO-UNDO.
DEFINE VARIABLE pcReturned AS INTEGER NO-UNDO.
/* initial value */
/* Just want to know the correct size of the pPrinterEnum MEMPTR */
SET-SIZE(pPrinterEnum)= 1208.
RUN EnumPrintersA(
OUTPUT res,
INPUT 2,
INPUT "",
INPUT 2,
INPUT-OUTPUT pPrinterEnum,
INPUT GET-SIZE(pPrinterEnum),
OUTPUT pcbNeeded,
OUTPUT pcReturned). /* Number of printers */
/* Get the size of the pPrinterEnum MEMPTR */
SET-SIZE(pPrinterEnum)= 0.
SET-SIZE(pPrinterEnum)= pcbNeeded.
RUN EnumPrintersA(
OUTPUT res,
INPUT 2,
INPUT "",
INPUT 2,
OUTPUT pcbNeeded,
/* Printer list */
DO i = 0 TO pcReturned - 1 :
SET-POINTER-VALUE(pPrinterInfo) = GET-POINTER-VALUE(pPrinterEnum) + (i * 84 ).
SET-POINTER-VALUE(lpPrinterName) = GET-LONG(pPrinterInfo,5).
lstPrinter:insert(string(GET-STRING(lpPrinterName,1)),1).
END.
/* Clean Up */
SET-SIZE(pPrinterEnum) = 0.
SET-SIZE(pPrinterInfo) = 0.
SET-SIZE(lpPrinterName) = 0.
END.
DO ON ERROR Undo, LEAVE
ON END-KEY UNDO, LEAVE:
DISPLAY cmdFind lstPrinter WITH FRAME frmMain.
ENABLE cmdFind lstPrinter WITH FRAME frmMain.
END.
WAIT-FOR CLOSE OF THIS-PROCEDURE.
