stored procedure send-sql-statement in progress
schaapie
In some of the documentation the mention a stored procedure "send-sql-statement" which should be there by default.
But...
Is it only available in an Oracle-db?
Can i even have stored-procedures on an progress-db?
If so, how can i create a stored-procedure in a progress-db which allows me to send a sql-statement. And how do I access the dataset which is returned?
Thanks
Schaapie
joey.jeremiah
ProgressTalk Moderator
Staff member
Progress has a SQL engine and you can also create stored procedures thru the SQL explorer.
Did you look at the "SQL Development" doc ?
