P 9.1E
O/S Windows XP SP3
DB on SLES 10
These screen shots are from Progress version 9.1E
ISSUE: Screen spaces crazy when not in V6Display mode.
The only change between the 2 images was V6Display=yes changed to V6Display=no in the .ini file.
We have not been able to figure out the settings where Progress finds "line height" or "character width" when not
using V6Display mode. The fact that the number of each menu item causes the period in the form to display on the next
line tells us that we still need to find another font specification setting so Progress can determine the appropriate "character
width". We have tried setting the following values in the .ini file to no avail.
relevant entries from .ini file
[startup]
V6FontNumber=0
DefaultV6UpdateFont=Bitstream Vera Sans Mono, size 11, BOLD
DefaultFont=Bitstream Vera Sans Mono, size 11, BOLD
DefaultFixedFont=Bitstream Vera Sans Mono, size 11, BOLD
PrinterFont=Bitstream Vera Sans Mono, size=12, BOLD
FrameSpacing=2
[fonts]
font0=Bitstream Vera Sans Mono, size 11, bold
font1=Bitstream Vera Sans Mono, size 11, bold
font2=Bitstream Vera Sans Mono, size 11
font3=Courier New, size 8
font4=Bitstream Vera Sans Mono, size 11
The FORM code that displays the menu is below:
FORM m-title AT 17
"Default Printer:" AT 62
prtr AT 79 SKIP(1)
optno[1] AT 3 optdesc[1] AT 5
optno[20] AT 40 optdesc[20] AT 42
optno[2] AT 3 optdesc[2] AT 5
optno[21] AT 40 optdesc[21] AT 42
optno[3] AT 3 optdesc[3] AT 5
optno[22] AT 40 optdesc[22] AT 42
optno[4] AT 3 optdesc[4] AT 5
optno[23] AT 40 optdesc[23] AT 42
optno[5] AT 3 optdesc[5] AT 5
optno[24] AT 40 optdesc[24] AT 42
optno[6] AT 3 optdesc[6] AT 5
optno[25] AT 40 optdesc[25] AT 42
optno[7] AT 3 optdesc[7] AT 5
optno[26] AT 40 optdesc[26] AT 42
optno[8] AT 3 optdesc[8] AT 5
optno[27] AT 40 optdesc[27] AT 42
optno[9] AT 3 optdesc[9] AT 5
optno[28] AT 40 optdesc[28] AT 42
optno[10] AT 3 optdesc[10] AT 5
optno[29] AT 40 optdesc[29] AT 42
optno[11] AT 3 optdesc[11] AT 5
optno[30] AT 40 optdesc[30] AT 42
optno[12] AT 3 optdesc[12] AT 5
optno[31] AT 40 optdesc[31] AT 42
optno[13] AT 3 optdesc[13] AT 5
optno[32] AT 40 optdesc[32] AT 42
optno[14] AT 3 optdesc[14] AT 5
optno[33] AT 40 optdesc[33] AT 42
optno[15] AT 3 optdesc[15] AT 5
optno[34] AT 40 optdesc[34] AT 42
optno[16] AT 3 optdesc[16] AT 5
optno[35] AT 40 optdesc[35] AT 42
optno[17] AT 3 optdesc[17] AT 5
optno[36] AT 40 optdesc[36] AT 42
optno[18] AT 3 optdesc[18] AT 5
optno[37] AT 40 optdesc[37] AT 42
optno[19] AT 3 optdesc[19] AT 5
optno[38] AT 40 optdesc[38] AT 42
"Enter Selection" AT 35 xx AT 51 /* BLANK */
WITH NO-LABELS NO-BOX NO-UNDERLINE DOWN FRAME menu1.
the version information below is not correct for this problem, see top...
O/S Windows XP SP3
DB on SLES 10
[startup]
V6FontNumber=0
FrameSpacing=2
[fonts]
FORM m-title AT 17
prtr AT 79 SKIP(1)
