Question Selectable Frame Selection Issue
Rob Case
Hi all,
I have a frame displaying data from a database query I performed. I have a statement that when I push F10 to display the order number. My issue is that I have to hit F10 2 times for the display statement to work (this is just for testing... i'll end up doing a separate task).
I did noticed there is a "Enter a unique identifier fro this order" at the bottom, not sure where that came from. Looked in the progress manual examples but I feel I'm missing something here. I have attached a screen shot of how it looks when I launch the program.
Any ideas why I must press F10 2 times?
for each wk_data no-lock break by wk_data.order:
  if first-of(wk_data.order) then
  var_count = var_count + 1.
end.
form wk_data.order with frame main-frame centered row 5 scroll 1 var_count down.
    display wk_data.order
            wk_data.cust_num
            wk_data.ship_name
            wk_data.date_req
            wk_data.order_status with frame main-frame.
    down with frame main-frame.
    end.
up var_count with frame main-frame.
REPEAT ON ENDKEY undo, leave:
  CHOOSE ROW order NO-ERROR WITH FRAME main-frame.
  on F10 anywhere do:
  display FRAME-VALUE format "x(9)".
end.
end.
Thanks in advance,
Rob
OpenEdge Release 10.2B08
RealHeavyDude
Well-Known Member
The message "Enter a unique identifier for this order" is coming from the help attribute of the (database) field. Although it can be overriden almost anywhere the definition of the (database) field is a good place to start.
Is this GUI or CHUI?
Heavy Regards, RealHeavyDude.
RealHeavyDude
Well-Known Member
On a second thought: I would move the trigger out of the repeat loop and out of the for each loop.
Rob Case
That did help. I ended up removing the repeat loop and moved the choose statement out of the for-each. Much better. Another issue came up since the repeat was removed. When the orders are listed and I scroll to the last entry, if I press the down arrow again, the program completes and ends. How can I force that F4 is the only way to exit the program such as if I scroll to the last entry displayed and the down arrow is pressed again, nothing happens?
Thanks for all of your help. Much appreciated RealHeavyDude.
