Sample Programe for Data Entry Screan
sunil
Hi Evryone,
I started learn Progress Appbuilder. The problem is I don't have sample code for the above matter if anyone can send me the sample code for Appbuilder programe or Web site it will grate help for me to achive my target pls help me as soon as posible.
Thaks All.
Jupiter
Dear Sunil,
If you have your database ready then
1. Connect to the database.
2. Create a new window.
3. Create some fill-ins.
4. Add a save button on your screen.
After that add code of follwoing type.
find <dbname>.<tblname> where <uniquefiled> = <fill-in:screenvalue in frame framename> no-lock no-error.
if not available <dbname>.<tblname> then
do:
create <dbname>.<tblname> .
assign
<dbname>.<tblname>.<fields> = <values>.
end.
Regards
