rayherring
I scrapped the HAproxy side of it since I decided to do websockets a different way, but the lighttpd side of things has been working quite nicely (and so much faster than Apache). For lighttpd, I am just running a stock standard setup (with the exception of the cgi-bin side of things). lighttpd.conf: server.modules = ( "mod_access", "mod_accesslog", "mod_alias", "mod_compress", "mod_redirect", "mod_setenv", ) server.document-root = "/var/www" server.upload-dirs = ( "/var/cache/lighttpd/uploads" ) server.errorlog = "/var/log/lighttpd/error.log" accesslog.filename = "/var/log/lighttpd/access.log" server.pid-file = "/var/run/lighttpd.pid" server.username = "www-data" server.groupname = "www-data" server.port = 80 # Keep-Alive stuff # Was at 32 and 3 server.max-keep-alive-requests = 0 server.max-keep-alive-idle = 3 index-file.names = ( "index.php", "index.html", "index.lighttpd.html" ) url.access-deny = ( "~", ".inc" ) static-file.exclude-extensions = ( ".php", ".pl", ".fcgi" ) compress.allowed-encodings = ("gzip", "deflate") compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" ) 10-cgi.conf (in /etc/lighttpd/conf-enabled) server.modules += ( "mod_cgi" ) $HTTP["url"] =~ "^/cgi-bin/" { cgi.assign = ( "" => "" ) } alias.url += ( "/cgi-bin" => "/usr/lib/cgi-bin/" ) Then in the /usr/lib/cgi-bin directory I just have my cgi script for my broker (eg. cgiip) which points to the host the DB is running on (that also has the actual broker and agents on it). I had to reduce the max-keep-alive-requests from the default as having it at 32 was causing issues. Response times (according to 'wtbman -i broker' have basically gone from 200ms or so down to about 10ms just by switching to lighttpd).
