James Palmer
I've retested this morning. 1) No, _sqlsrv2.exe is not spawned 2) OE 64 bit 3) No OE 11 available and java is an unrecognised command 5) If I reconnect there is nothing on in the logs I think I've been through all the KB articles on it. I've set the admin service to use the account of the user that created the DB, I've also made sure that the user account has full access to the database folder. When I cancel the connect attempt I finally get something in the logs. [2017/12/06@12:14:46.974+0000] P-2132 T-2100 I BROKER 1: (8842) Could not spawn a SQL server. [2017/12/06@12:14:46.974+0000] P-2132 T-2100 I BROKER 1: (796) Error writing msg, socket=712 errno=10054 usernum=1 disconnected. [2017/12/06@12:14:48.216+0000] P-6844 T-8804 I SQLSRV2 8: (-----) SQL Server 10.2B.08 started, configuration: "l_idx_cmo_pts.defaultconfiguration" [2017/12/06@12:14:48.221+0000] P-6844 T-8804 I SQLSRV2 8: (-----) Failure during dsmUserSecureConnect (-1) [2017/12/06@12:14:48.229+0000] P-6844 T-8804 I SQLSRV2 8: (-----) "odbcservergroup" started on IPv4 port 3020 for address 0.0.0.0, pid 6844 (0x00001abc). [2017/12/06@12:14:48.229+0000] P-6844 T-8804 I SQLSRV2 8: (-----) Thread stack size: 1024000 (bytes). [2017/12/06@12:14:48.229+0000] P-6844 T-8804 I SQLSRV2 8: (-----) DLC from ENVIRONMENT VARIABLE is: C:\Progress\OpenEdge [2017/12/06@12:14:48.229+0000] P-6844 T-8804 I SQLSRV2 8: (-----) WRKDIR from REGISTRY is: C:\OpenEdge\WRK\ [2017/12/06@12:14:48.229+0000] P-6844 T-8804 I SQLSRV2 8: (-----) JDKHOME from REGISTRY is: C:\Progress\OpenEdge\jdk [2017/12/06@12:14:48.229+0000] P-6844 T-8804 I SQLSRV2 8: (-----) JREHOME from REGISTRY is: C:\Progress\OpenEdge\jre [2017/12/06@12:14:48.229+0000] P-6844 T-8804 I SQLSRV2 8: (-----) CLASSPATH from DEFAULT is: [2017/12/06@12:14:48.229+0000] P-6844 T-8804 I SQLSRV2 8: (-----) PROSQL_LOCKWAIT_TIMEOUT value is: 5 seconds [2017/12/06@12:14:48.229+0000] P-6844 T-8804 I SQLSRV2 8: (-----) Failure during dsmShutdownUser (-1). Proceeding.
