singh.mitesh@gmail.com
Hello All , Many thanks for your suggestions . I installed Service Pack 2 for 11.6 thinking it could fix it , but after installing service pack 2 OpenEdge Explorer stopped working . I then thought it could be because of two versions of openedge on my system and then i decided to uninstall both OE 11.6 64 bit and OE10.2B 32 bit from mys syatem . After uninstalling both , i again installed OE 11.6 . I check OpenEdge Explorer and it worked . Then i again installed Service pack 2 for 11.6 and again OE Explorer stopped working . It gives message "Unable to connect for http://localhost:9090/ " I am not sure that service pack will fic the issue but , is somebody has any idea that service pack is messing the OE explorer then it will be helpfull .
