marian.edu
Octavio, just because you’ve closed the form it doesn’t mean the instance is gone, you still have a reference to it inside the caller (unless you we’re quick to delete the object) so just use property/method access to find the info you need. If you want the caller to react to changes in that form while being displayed named events works fine (OO version of publish/subscribe). Cheers Marian Edu Acorn IT www.acorn-it.com www.akera.io +40 740 036 212
