George Potemkin
Edwin, Your database is NOT corrupted. > Corrupt block detected when attempting to release a buffer. Progress did not read block from disk. You did not post the text of error 1124: SYSTEM ERROR: Wrong dbkey in block. Found dbkey1, should be dbkey2 in area num 11. I guess the found dbkey is real one: multiple by RPB (=64 in your case), below HWM. > Error message (11 times): Who reported it first? Did watchdog report a dead user? I bet a client's session died (or was killed) while reading data from disk. Buffer header stored the information about dbkey that the session was going to retrieve from disk ("should be dbkey"). The buffer itself stored some old block ("found dbkey"). > Can I do more to find out if we really have a db corruption? The quickest way is: find any_table_in_the_area no-lock where recid(any_table_in_the_area) eq should_be_dbkey_in_1422
