[progress Communities] [progress Openedge Abl] Forum Post: Re: Connect To Websphere Mq...
Anand Adike
Hi Fuelfire, Following are the two ways to connect IBM WebSphere MQ. Local Queue Manager Remote Queue Manager (using JNDI approach) Procedure to setup Local Queue Manager: Step 1: Need to update the WebSphereMQ connection factory class names in $DLC/properties/jmsProvider.propeties as shown below: [WebsphereMQ] javax.jms.ConnectionFactory=com.ibm.mq.jms.MQConnectionFactory javax.jms.QueueConnectionFactory=com.ibm.mq.jms.MQQueueConnectionFactory javax.jms.TopicConnectionFactory=com.ibm.mq.jms.MQTopicConnectionFactory Step 2: Update $DLC/properties/AdminServerPlugins.propertes file with WebSphereMQ libraries under [PluginPolicy.Progress.SonicMQ] section as shown below. [PluginPolicy.Progress.SonicMQ] pluginclasspath=C:\Progress115\OpenEdge/java/progress.jar,C:\PROGRA~2\IBM\WEBSPH~1\java\lib\com.ibm.mqjms.jar classpath=C:\Progress115\OpenEdge/java/progress.jar,C:\PROGRA~2\IBM\WEBSPH~1\java\lib\com.ibm.mqjms.jar jvmargs=-DsonicMQExtensions=false -DjmsProvider=WebSphereMQ Step 3: We need to start SonicMQ adapter with following command from proenv section. proenv>adaptman -i sonicMQ1 -start Step 4: Provide the quque manager name as a value in Broker-URL in pcode and run it. Procedure to setup Remote Queue Manager: We need to follow below one extra step to connect WebSphere MQ remotely. Develop AdminObjectFinder.java by specifying PROVIDER_URL and generate jar out of it and place it in pluginclasspath and classpath under [PluginPolicy.Progress.SonicMQ] . Please find the attached sample pcode. Thanks, Anand.
