P
Phani Sajja
The test case is considered pass if the error specified in expected attribute is raised. That is a sample example. When you are testing application logic (a method for example), that might throw exceptions for certain input. If you want to test your method is throwing an exception for certain input then you can specify that as part of expected attribute as showing in above snippet.
