Jean Richert
From: noreply@progress.com Sent: Friday, March 4, 2016 6:22:52 AM (UTC+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna To: Jean Richert Subject: Progress Alert and Notification Service: OpenEdge Dear Jean Richert, Below are your new OpenEdge notifications. Article - ALL Publish Date Article# Solution Title 03-Mar-2016 22:08 EST 000067059 How to create a log to monitor the AppServer agents on Windows 03-Mar-2016 17:10 EST 000067044 Cannot read field from record, not enough fields. 03-Mar-2016 15:58 EST 000067057 HTTP client fails if server uses NIO 03-Mar-2016 15:57 EST 000067052 Examples of an OEMGT Job to kill an active appserver 03-Mar-2016 14:37 EST 000067056 Internal error in SQL engine when a query contains a complex LIKE predicate 03-Mar-2016 13:59 EST 000067054 Is it possible to enable SSL for SQL broker only? 03-Mar-2016 09:42 EST 000067048 How to determine if record is new in a write tigger 03-Mar-2016 09:30 EST 000067046 Errors (2624) (328) (10488) using the MS SQL dataserver and the native sequence generator 03-Mar-2016 03:53 EST 000067019 Editing phrase READKEY with an Editor widget doesn't trap keys 03-Mar-2016 03:35 EST 000067018 64 bit 11.5.1 showcfg command shows 32 bit 11.5.1 licenses instead of installed 64 bit 11.5.1 licenses 03-Mar-2016 03:30 EST 000067017 OEBPM DB Adapter cannot find table/view/synonynm at run time 03-Mar-2016 03:16 EST 000067016 How to configure OEBPM DB Adapter with the sports2000 database? 03-Mar-2016 03:06 EST 000067015 How to create a datasource in OEBPM to connect to an external database? copyright (C) 2014 Progress Software Corporation. All Rights Reserved. Modify or update your Subscription Service NOTICE: This message may contain an advertisement or solicitation as defined by the CAN-SPAM Act of 2003. This message was sent by Progress Software, 14 Oak Park Drive, Bedford, MA 01863 USA.
