Hi Peggers,
iam trying to import the following from a csv file:
1022;HR STD SHORT CORRIDOR 72;BFC04; +1.50; +0.75;L;100630029
I have Problems with the values +1.50 and +0.75.
The format of the field in the table is +9.99 (both).
But after importing, i found the values 350.0 and 125.00 in the this fields.
Is that a formatting problem ?
My import code:
def var file as char no-undo.
file = "c:\vad.csv".
input from value(file).
repeat:
create vaddet.
import delimiter ";" vaddet.Pcode vaddet.bez ^ vaddet.BC vaddet.Tor ~
vaddet.Richtg vaddet´.ECode.
end.
input close.
Greets
Make
My import code:
repeat:
create vaddet.
end.
input close.
Greets
Make
