franklin1232
I had a problem finding the trigger code in my application and I am pretty sure it's a propath problem. The path to the trigger in data dictionary is "db/trg/shiphead/write.p" The full path is "u:\mfgsys61\db\trg\shiphead\write.p" This is a snippet from the custom ini file our ERP vendor uses.
[Startup]
V6Display=no
;ImmediateDisplay=yes
;MultitaskingInterval=100
DLC=U:\progress
Use-3D-Size=No
PROBUILD=U:\progress\Probuild
PROPATH=.,U:\mfgsys61
PrinterFont=Courier New,Size=12
AllowDesignMode=no
nosplash=yes
I am trying to set the propath on my machine which has a local install of progress to "u:\mfgsys61". I changed it in the registry and added an environment variable but I still get an error saying it can't find the write.r trigger for the shiphead table. I am not currently using the vendors custom ini file, but should I really have to. All I need is the propath, right?
[Startup]
V6Display=no
DLC=U:\progress
Use-3D-Size=No
AllowDesignMode=no
nosplash=yes
