Ok to better explain this, I have Window1.w calling Window2.w calling Dialog3.w.
Example:
Window1.w --> Window2.w --> Dialog3.w
When I close Dialog3.w sometimes Window2.w moves to the top like it should and becomes the active window. Then again sometime when I close Dialog3.w, Window1.w moves to the top and becomes the active window.
To me it seems like Dialog3.w is unsure of it's parent or who called it. It there a way I can explicitly make sure that every time Dialog3.w is closed that only Window2.w moves to the top or becomes the active window?
Here is how I am calling Dialog3.w from Window2.w:
Example:
DEFINE VAR ProcedureHandle AS HANDLE NO-UNDO.
FIND Company WHERE CompanyID = fCompID NO-LOCK NO-ERROR.
RUN Dialog3.w PERSISTENT SET ProcedureHandle
(OUTPUT o-RecID,
OUTPUT o-ReturnCode,
OUTPUT o-CBSalesmanID,
INPUT IF AVAILABLE Company THEN ROWID(Company) ELSE ?).
