Problem while starting the DB
Hi All,
I am unable to start the DB as below error comes.
Please advice to recover the error.
$DLC/bin/_mprosrv cfacprtfuq
11:48:40 BROKER : Semaphore limit exceeded (1131)
11:48:40 BROKER : Removed shared memory with segment_id: 13041787
11:48:40 BROKER : ** This process terminated with exit code 2. (8619)
Casper
ProgressTalk.com Moderator
Staff member
OS? Progress version? Other databases running at that server? What Startup parameters used?
Anyhow you are reaching some kind of OS limit regarding semphores.
Casper
Capser,
OS - Linux
Progress version - 91e
Other databases running at that server - Yes remaining are working fine
Startup parameters used for the reported db is below:
-cpinternal GB2312
-cpstream GB2312
-cprcodein GB2312
-L 184800
-c 350
-Ma 3
-Mn 1
-spin 50
-semsets 1
-n 12
Pls advice me if any to be changed.
Thanks and regards
Ramya
Casper
Staff member
What flavour of Linux?
Are you using dataserver? I believe -c is a dataserver parameter.
-semsets 1 is the default value in 9.1E.
You can ommit -spin as well.
For testing purposes you could increase the values for SEMNI and SEMMNS.
Regards,
Casper.
Where i can specify the parameters SEMNI and SEMMNS ?
in the same parameter file ?
how much can i set the values to ?
Please advise.
Thanks for your quick replies.
TomBascom
Curmudgeon
$ man sysctl
or
$ cat /proc/sys/kernel/sem
-spin 50 is probably not a very good value. -spin 5000 is probably much more appropriate. -semsets 1 is superfluous. -c is too (unless you're seeing an error that says otherwise). Also -- why specify -Ma & -Mn if you aren't specifying -S? Are you starting a secondary broker somewhere?
