I'm using a sample code to Dump raw data to printer that I found at www.global-shared.com, and works well, but the characters with accents (Words in Spanish) are changed by other characters, even changing to different character tables.
I'm trying an utility called Rawprint, that is suggested in some threads here at www.progresstalk.com, and this utility print characters with accents well, but I don't want to use it interface.
Anybody Knows if I'm doing something wrong, or is there any solution to resolve this problem ??
I really appreciate your help. Thank you.
This is the code I'm using:
DEFINE INPUT PARAMETER PrinterName AS CHAR NO-UNDO. /* As set in Printer properties */
DEFINE INPUT PARAMETER FILENAME AS CHAR NO-UNDO.
DEFINE VARIABLE X AS INT NO-UNDO.
DEFINE VARIABLE hPrinter AS INT NO-UNDO.
DEFINE VARIABLE hFile AS INT NO-UNDO.
DEFINE VARIABLE pBuf AS MEMPTR NO-UNDO.
DEFINE VARIABLE FileSize AS INT NO-UNDO.
DEFINE VARIABLE iSize AS INT NO-UNDO.
DEFINE VARIABLE xSize AS INT NO-UNDO.
DEFINE VARIABLE pFileName AS MEMPTR NO-UNDO.
DEFINE VARIABLE OutFileName AS CHAR NO-UNDO.
DEFINE VARIABLE pOutFileName AS MEMPTR NO-UNDO.
DEFINE VARIABLE DataType AS CHAR NO-UNDO.
DEFINE VARIABLE pDataType AS MEMPTR NO-UNDO.
DEFINE VARIABLE pDocInfo AS MEMPTR NO-UNDO.
RUN OpenPrinterA (PrinterName,OUTPUT hPrinter,0, OUTPUT X).
IF X = 0
THEN MESSAGE "Error opening printer: " PrinterName VIEW-AS ALERT-BOX.
ELSE DO:
RUN CreateFileA (FILENAME , -2147483648,0,0,3,128,0,OUTPUT hFile). /* -2147483648 = $80000000 */
IF hFile = -1
THEN MESSAGE "Error opening file: " FILENAME VIEW-AS ALERT-BOX.
ELSE DO:
RUN GetFileSize (hFile,0,OUTPUT FileSize).
IF FileSize = -1
THEN MESSAGE "Wrong file size" VIEW-AS ALERT-BOX.
ELSE DO:
SET-SIZE(pBuf) = FileSize.
RUN ReadFile(hFile,pBuf,FileSize,OUTPUT iSize,0, OUTPUT X).
IF X = 0
THEN MESSAGE "Error reading file: " FILENAME VIEW-AS ALERT-BOX.
ELSE DO:
IF iSize = 0
THEN MESSAGE "Attempt to read beyond end of file:" FILENAME VIEW-AS ALERT-BOX.
ELSE DO:
OutFileName = "".
DataType = "RAW".
SET-SIZE(pDocInfo) = 12.
SET-SIZE(pFileName) = LENGTH(FILENAME) + 1.
PUT-STRING(pFileName,1) = FILENAME.
SET-SIZE(pOutFileName) = LENGTH(OutFileName) + 1.
PUT-STRING(pOutFileName,1) = OutFileName.
SET-SIZE(pDataType) = LENGTH(DataType) + 1.
PUT-STRING(pDataType,1) = DataType.
PUT-LONG(pDocInfo,1) = GET-POINTER-VALUE(pFileName).
PUT-LONG(pDocInfo,5) = GET-POINTER-VALUE(pOutFileName).
PUT-LONG(pDocInfo,9) = GET-POINTER-VALUE(pDataType).
RUN StartDocPrinterA (hPrinter,1,pDocInfo,OUTPUT X).
IF X = 0 THEN DO:
RUN GetLastError(OUTPUT X).
MESSAGE "Error : " X VIEW-AS ALERT-BOX.
END.
RUN WritePrinter(hPrinter,pBuf,iSize,OUTPUT xSize,OUTPUT X).
IF X = 0 THEN DO:
MESSAGE "Error writing to printer: " PrinterName iSize xsize X VIEW-AS ALERT-BOX.
END.
RUN EndDocPrinter(hPrinter,OUTPUT X).
END.
END.
END.
RUN CloseHandle(hFile,OUTPUT X).
IF X = 0 THEN MESSAGE "Error closing file: " FILENAME.
END.
RUN ClosePrinter(hPrinter,OUTPUT X).
IF X = 0
THEN MESSAGE "Error closing printer: " PrinterName VIEW-AS ALERT-BOX.
END.
SET-SIZE(pBuf) = 0.
SET-SIZE(pDocInfo) = 0.
SET-SIZE(pFileName) = 0.
SET-SIZE(pOutFileName) = 0.
SET-SIZE(pDataType) = 0.
/* DLL Procedures */
PROCEDURE GetLastError EXTERNAL "kernel32.dll" :
DEFINE RETURN PARAMETER X AS LONG.
END PROCEDURE.
PROCEDURE StartDocPrinterA EXTERNAL "winspool.drv" :
DEFINE INPUT PARAMETER hPrinter AS LONG.
DEFINE INPUT PARAMETER Level AS LONG.
DEFINE INPUT PARAMETER pDocInfo AS MEMPTR.
END PROCEDURE.
PROCEDURE EndDocPrinter EXTERNAL "winspool.drv" :
END PROCEDURE.
PROCEDURE CreateFileA EXTERNAL "kernel32.dll" :
DEFINE INPUT PARAMETER lpFileName AS CHAR.
DEFINE INPUT PARAMETER dwDesiredAccess AS LONG.
DEFINE INPUT PARAMETER dwShareMode AS LONG.
DEFINE INPUT PARAMETER lpSecurityAttributes AS LONG.
DEFINE INPUT PARAMETER dwCreationDistribution AS LONG.
DEFINE INPUT PARAMETER dwFlagsAndAttributes AS LONG.
DEFINE INPUT PARAMETER hTemplateFile AS LONG.
DEFINE RETURN PARAMETER hFile AS LONG.
END PROCEDURE.
PROCEDURE ReadFile EXTERNAL "kernel32.dll" :
DEFINE INPUT PARAMETER hFile AS LONG.
DEFINE INPUT PARAMETER lpBuffer AS MEMPTR.
DEFINE INPUT PARAMETER nNumberOfBytesToRead AS LONG.
DEFINE OUTPUT PARAMETER lpNumberOfBytesRead AS LONG.
DEFINE INPUT PARAMETER lpOverlapped AS LONG.
END PROCEDURE.
PROCEDURE WritePrinter EXTERNAL "winspool.drv" :
DEFINE INPUT PARAMETER pBuf AS MEMPTR.
DEFINE INPUT PARAMETER cbBuf AS LONG.
DEFINE OUTPUT PARAMETER lpdwWritten AS LONG.
END PROCEDURE.
PROCEDURE OpenPrinterA EXTERNAL "winspool.drv" :
DEFINE INPUT PARAMETER pPrinterName AS CHAR.
DEFINE OUTPUT PARAMETER phPrinter AS LONG.
DEFINE INPUT PARAMETER pDefault AS LONG.
END PROCEDURE.
PROCEDURE ClosePrinter EXTERNAL "winspool.drv" :
END PROCEDURE.
PROCEDURE GetFileSize EXTERNAL "kernel32.dll" :
DEFINE INPUT PARAMETER lpFileSizeHigh AS LONG.
DEFINE RETURN PARAMETER FileSize AS LONG.
END PROCEDURE.
PROCEDURE CloseHandle EXTERNAL "kernel32.dll" :
DEFINE INPUT PARAMETER hObject AS LONG.
END PROCEDURE.
IF X = 0
ELSE DO:
IF hFile = -1
ELSE DO:
IF FileSize = -1
ELSE DO:
IF X = 0
ELSE DO:
IF iSize = 0
ELSE DO:
OutFileName = "".
DataType = "RAW".
IF X = 0 THEN DO:
END.
IF X = 0 THEN DO:
END.
END.
END.
END.
END.
IF X = 0
END.
SET-SIZE(pBuf) = 0.
END PROCEDURE.
END PROCEDURE.
END PROCEDURE.
END PROCEDURE.
END PROCEDURE.
END PROCEDURE.
END PROCEDURE.
END PROCEDURE.
END PROCEDURE.
END PROCEDURE.
