Sabrina01
Hi All,
I need help -.- Since 2 days I'm trying to build a CSV-Database-Export with Progress, but no success till now...
(btw: I'm from germany and my english is not even the best, so I hope you will understand my Problem)
I am at home now so I can't even post my Code -.-
The Problem is the loop-code, which means I declare the String 'R,L,B,D,G', these are the possible entrys in my Table.Type - Field.
There is also a Table.RefNr - Field, Table.Type and this one together are building the Primary-Key.
Now I intended to go by a do-block with if-block inside to get every TYPE-REFNR combo. I just want every row in this CSV, I opened the Stream and it wont stop to write,
this means I always have to kill the Code cause it doesn't stop after round about 550.000 sets of Data (big Table) it just starts all over.
Please help me 1 week ago I started with Progress nearly 0 programming experiences...
Greetings from Germany, Sabrina
