Load-picture strange behaviour
  • Thread starter progresscommunities@progr
  • Start date
P
Hi,
OE10.2ASP03 - Win 7
We're having a problem with the load-picture statement.
We have two programs that uses the same OCX (Gantt-chart).
It's possible to load icons in the chart to display.
Everything works fine when we run our application with 'prowin32.exe' in the shortcut.
The piece of code is :
DEF VAR chpic AS COM-HANDLE.
chpic = LOAD-PICTURE(G-clientimg + "alertplanning.ico").
Strange thing is, when we change the application shortcut to 'prowc.exe' the webclient just crashes on the load-picture statement.
When we change 'alertplanning.ico' to a jpg-file it works with prowin32.exe and prowc.exe. Problem is then that the OCX only can load .ico-files.
Is there a workaround, because it seems that prowc.exe can't handle load-pictue(".ico").
Kind regards,
Bart Syryn
