which operating system u r using for progress db. when u r using linux OS , u can use chmod permissions for read, write to lock on every file.
I hope this solution wil be tad relevant to your question.
Assuming that you are concerned about a 4GL user you would do this through the data dictionary. Pick the Admin -> Security -> Edit Data Security Option. Then pick the tables that you want to prevent this user from writing and add the string ",!username" to the CAN-WRITE, CAN-CREATE and CAN-DELETE fields as appropriate.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
