Group by and sub total
ss_kiran
I need to populate temporary table from a database table. The records of the table are somthing like this
Country Type Amount
Ind FNT 10
Ind FNT 9
Ind FGH 1
Ind Sales 50
Ind FGH 5
USA FGH 4
USA FNT 3
USA Sales 100
USA FNT 1
USA FGH 39
I want to creat a Temp table which would have one record for every county and type. for ex from above records i should have
Ind FNT 19
Ind FGH 6
Ind Sales 50
USA FNT 4
USA FGH 43
USA Sales 100
Thanks
Kiran Shankar
joey.jeremiah
ProgressTalk Moderator
Staff member
 * group by temp-table
define temp-table ttGroup no-undo
    field tCountry  as char
    field tCategory as char
    field tTotal    as deci
    index tCntryCat is primary unique
          tCountry
          tCategory.
run fillGroup.
 * fill group by temp-table
procedure fillGroup:
    /* clear previous data */
    empty temp-table ttGroup.
     * loop through my_table
     * and break into country, category groups
    for each my_table no-lock
        break
        by my_table.country
        by my_table.category:
        /* accumulate amount for country, category group */
        accumulate my_table.amount ( total by my_table.category ).
         * when a country, category group ends
         * create a record in the group temp-table
         * with the total amount for the group
        if last-of( my_table.category ) then do:
            create ttGroup.
            assign
                ttGroup.tCountry    = my_table.country
                ttGroup.tCategory   = my_table.category
                ttGroup.tTotal      =
                    ( accum total by my_table.category mt_table.amount ).
        end. /* last-of( category ) */
    end. /* each my_table */
end procedure. /* fillGroup */
hth :)
jpachut
Dear SS Kiran
I am also trying to do a subtotal by a specific field name and I was wondering if the suggestion you received worked or if you found another way to get your groub by and subtotal ?
JP
ss_kiran
Hello JP,
Yes the solution provided above by Joey did help me. I was able to achieve what i wanted.
Thanks
Kiran
