Forum Post: RE: WSA: Setting NS port to a non-standard location
  • Thread starter Phillip Molly Malone
  • Start date
P
Hmmm... We may have a miss understanding of the default props. They would be the ones given to a newly deployed webservice. Is that what you expected? i.e. if you change default props but still have 4 webservices already deployed, they wouldn't change there default port (I don't believe). You would have to disable the webservices and then change and save the port change and then enable them again. I am also not sure if you change the file directly if you would need to restart the JSE that you are using.
