Mike Fechner
I'm trying to increase Progress Developer Studio performance by adding memory to it. It's obvious that there are memory limits in a 32 bit JVM - so I am trying to use a 64 bit JVM and a 64 bit Eclipse base install with PDSOE. So far with little luck: JRE version: Java(TM) SE Runtime Environment (build 1.7.0_67-b01) Eclipse: eclipse-java-kepler-SR1-win32-x86_64.zip Integrate Architect was not successful (see below): OpenEdge 11.4.0.00 (com.openedge.pdt.feature.group 11.4.0.00) requires 'com.openedge.pdt.platform.win64 [11.4.0.00]' but it could not be found That is obvious. So what I could do, is install 64 bit OE on another machine and integrate the PDSOE with a 64 bit Eclipse instance there - and copy that back to the machine with 32 bit OpenEdge installed. Before I do that, what is the expectation: Will it work? Will the 64 bit PDSOE work with prowin32.exe, will the Visual Designer work? The reason why I'm stuck on 32 bit Progress with my main development machine is that some projects still require some Active X Controls that are 32 bit only. proenv oeide\integrateArchitect.bat -install c:\Eclipse\431\eclipse proenv REM InstallUtils Version 2.4 proenv echo off Installing com.openedge.pdt.feature.group 11.4.0.00. Installation failed. Cannot complete the install because one or more required items could not be foun d. Software being installed: Progress Developer Studio for OpenEdge 11.4.0.00 (com .openedge.pdt.feature.group 11.4.0.00) Missing requirement for filter properties ~= $0: Progress Developer Studio for OpenEdge 11.4.0.00 (com.openedge.pdt.feature.group 11.4.0.00) requires 'com.open edge.pdt.platform.win64 [11.4.0.00]' but it could not be found Application failed, log file location: C:\Progress\OpenEdge114\install\oeide\Pro gressInstaller\config\1412884967429.log !SESSION 2014-10-09 22:02:47.306 ----------------------------------------------- eclipse.buildId=unknown java.version=1.7.0_45 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE Framework arguments: -application com.progress.installer.application -installFe ature com.openedge.pdt -productRoot C:\Progress\OpenEdge114\oeide -targetRoot c: \Eclipse\431\eclipse -productName Architect -productRepoPrefix Architect -tpRepo Prefix Architect_Third_Party -JAVA_LOCATION C:\Progress\OpenEdge114\jre\bin\\jav aw.exe Command-line arguments: -consoleLog -application com.progress.installer.applica tion -installFeature com.openedge.pdt -productRoot C:\Progress\OpenEdge114\oeide -targetRoot c:\Eclipse\431\eclipse -productName Architect -productRepoPrefix Ar chitect -tpRepoPrefix Architect_Third_Party -JAVA_LOCATION C:\Progress\OpenEdge1 14\jre\bin\\javaw.exe !ENTRY org.eclipse.equinox.p2.director 4 10053 2014-10-09 22:02:49.813 !MESSAGE Cannot complete the install because one or more required items could no t be found. !SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2014-10-09 22:02:49.814 !MESSAGE Software being installed: Progress Developer Studio for OpenEdge 11.4.0 .00 (com.openedge.pdt.feature.group 11.4.0.00) !SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2014-10-09 22:02:49.815 !MESSAGE Missing requirement for filter properties ~= $0: Progress Developer Stu dio for OpenEdge 11.4.0.00 (com.openedge.pdt.feature.group 11.4.0.00) requires ' com.openedge.pdt.platform.win64 [11.4.0.00]' but it could not be found Not merging eclipse.ini/config.ini as both flags updateParams and addMissingPara ms are set to false or are not specified
