Connect OpenEdge 10.1B with SQL Explorer Tool
andre060508
I want to connect OpenEdge 10.1B with the SQL Explorer Tool.
So I use the following link:
C:\PROGRESS\OpenEdge10.1B\bin\jvmStartw.exe -f "C:\PROGRESS\OpenEdge10.1B\sqlexp.prm"
Connection URL:
jdbc:datadirect:eek:penedge://localhost:15102;databaseName=pavar
I can see the GUI, but when I try to connect I get this Error:
java.lang.NoClassDefFoundError
at sun/rmi/server/RemoteProxy.getSkeleton
at sun/rmi/server/UnicastServerRef.setSkeleton
at sun/rmi/server/UnicastServerRef.exportObject
at java/rmi/server/UnicastRemoteObject.exportObject
at java/rmi/server/UnicastRemoteObject.<init>
at com/progress/common/networkevents/EventBroker.<init>
at com/progress/vj/explorer/ProgressExplorer.getClientEventBroker
at com/progress/vj/util/ProDialog.<clinit>
at com/progress/vj/util/ProDialog.getActiveProDlg
at com/progress/vj/util/ProMsgBox.show
at com/progress/vj/util/ProMsgBox.error
at com/progress/vj/sql/explorer/SQLExplorerGUI.workingCallback
at com/ms/lang/Delegate.dynamicInvoke0
at com/ms/wfc/ui/Control.invokeMarshaledCallback
at com/ms/wfc/ui/Control.wndProc
at com/ms/wfc/ui/Form.wndProc
at com/ms/wfc/app/Application$ParkingForm.wndProc
at com/ms/wfc/ui/Control$ControlWindow.wndProc
at com/ms/wfc/app/Window.callback
at com/ms/wfc/win32/Windows.DispatchMessage
at com/ms/wfc/app/Application$ThreadContext.runMessageLoop
at com/ms/wfc/app/Application.run
at com/progress/vj/sql/explorer/SQLExplorerGUI.main
Questions: Why is there no link for the SQL Explorer Tool in OpenEdge 10.1A and 10.1B?
Is it possible to use it and how can I solve this problem.
Casper
ProgressTalk.com Moderator
Staff member
Starting 10.1A the SQL explorer GUI was dropped from the release. You can still use the character version. (sqlexp.bat) or you can use any other GUI sql tool. (sQuirrel, DB navigator from OE architect etc.... ).
Casper.
Lieven
> Connection URL:
some hints to explore to get your jdbc working:
(1)
You must include the following jar files in your classpath:
%DLC%/java/openedge.jar;%DLC%/java/util.jar:%DLC%/java/base.jar
see also:
http://www.psdn.com/library/servlet/KbServlet/download/111-102-98/dmsdv.pdf
(2)
change the URL:
jdbc:datadirect:eek:penedge://host:port;databaseName=dns;defaultSchema=pub
found in this link:
http://knowledgebase.datadirect.com/kbase.nsf/SupportLink+Online/12273?OpenDocument
(3)
add the bin directory of progress to the path of windows
example:
PATH=%PATH%;D:\Develop\Progress\DLC\dlc9.1d\bin
good luck,
lieven
