When progress message pop up with buttons Yes-No,
I need to create a barcode that will work instead of keyborad when scanned.
So, when user Scan "Yes" barcode, progress pop up message
wil behave like key "Y or Alt-Y" whas pressed and another
barcode for "No" button.
Is it possible to do?
Thank you,
Alex Serebrenik
SerebrenikA@zomax.com
Thank you,
Alex Serebrenik
