Control files changes are NOT maintained or reported.what we have done is program trigger for each table (control) export the old/new value to a text file.
/* Developed By : Kishor Chari Date : 26th Sept 2004 ECO# */
/* Database Trigger for control files in MFG/PRO to create file output */
/* If modified. Both old & New Values are sent to the output file */
TRIGGER PROCEDURE FOR WRITE OF adc_ctrl OLD buffer old_adcctrl.
DEF VAR FILE_name AS c.
{mfdeclre.i}
FIND FIRST CODE_mstr NO-LOCK WHERE CODE_fldname = "control_file"
AND CODE_value = "File" NO-ERROR.
FILE_name = CODE_cmmt + "\" + "adctrl" + STRING ( YEAR (TODAY) ,"9999")
+ STRING (DAY (TODAY), "99")
+ STRING (MONTH (TODAY) , "99")
+ SUBSTRING ( STRING (TIME, "HH:MM"),1,2 )
+ SUBSTRING ( STRING (TIME, "HH:MM"),4 ) +
".txt".
OUTPUT TO VALUE (FILE_name) APPEND PAGED PAGE-SIZE 60.
{mfphead.i}
PUT "**** OLD VALUE ****" SKIP
"*******************" SKIP
"User: " + GLOBAL_userid FORMAT 'x(30)'
"Date: " + STRING (TODAY) FORMAT 'x(15)'
"Time: " + STRING (TIME ,"HH:MM:SS" ) FORMAT 'x(15)'.
DISP OLD_adcctrl WITH STREAM-IO DOWN FRAME x1 2 COL
SIDE-LABELS WIDTH 100.
PUT SKIP (2)
"**** NEW VALUE ****" SKIP
DISP adc_ctrl WITH STREAM-IO DOWN FRAME x2 2 COL
DISP
"************ End of Report ************"
WITH STREAM-IO DOWN FRAME x3 WIDTH 50 CENTERED.
