Sha2nk777
Hello All,
Greetings,
I have the version of progress( i.e. openedge 11.7.1 ) and try to connect it with Pentaho Data Integration (Spoon) through ODBC connection.
my connection type is: generic database
access : ODBC
i am using JDK : jdk1.8.0_161
Database Name : sp2k
ODBC DSN Name is : test
While connection with PENTAHO (spoon) when i check the test connection it show me Error like below:
/********************************* ERROR************************************/
Error connecting to database [sp2k] rg.pentaho.di.core.exception.KettleDatabaseException:
Error occurred while trying to connect to the database
Driver class 'sun.jdbc.odbc.JdbcOdbcDriver' could not be found, make sure the 'Generic database' driver (jar file) is installed.
org.pentaho.di.core.exception.KettleDatabaseException:
at org.pentaho.di.core.database.Database.normalConnect(Database.java:472)
at org.pentaho.di.core.database.Database.connect(Database.java:370)
at org.pentaho.di.core.database.Database.connect(Database.java:341)
at org.pentaho.di.core.database.Database.connect(Database.java:331)
at org.pentaho.di.core.database.DatabaseFactory.getConnectionTestReport(DatabaseFactory.java:80)
at org.pentaho.di.core.database.DatabaseMeta.testConnection(DatabaseMeta.java:2782)
at org.pentaho.ui.database.event.DataHandler.testDatabaseConnection(DataHandler.java:607)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.pentaho.ui.xul.impl.AbstractXulDomContainer.invoke(AbstractXulDomContainer.java:313)
at org.pentaho.ui.xul.impl.AbstractXulComponent.invoke(AbstractXulComponent.java:157)
at org.pentaho.ui.xul.impl.AbstractXulComponent.invoke(AbstractXulComponent.java:141)
at org.pentaho.ui.xul.swt.tags.SwtButton.access$500(SwtButton.java:43)
at org.pentaho.ui.xul.swt.tags.SwtButton$4.widgetSelected(SwtButton.java:137)
at org.eclipse.swt.widgets.TypedListener.handleEvent(Unknown Source)
at org.eclipse.swt.widgets.EventTable.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Widget.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Unknown Source)
at org.eclipse.swt.widgets.Display.readAndDispatch(Unknown Source)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820)
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.pentaho.di.ui.xul.KettleDialog.show(KettleDialog.java:80)
at org.pentaho.di.ui.xul.KettleDialog.show(KettleDialog.java:47)
at org.pentaho.di.ui.core.database.dialog.XulDatabaseDialog.open(XulDatabaseDialog.java:118)
at org.pentaho.di.ui.core.database.dialog.DatabaseDialog.open(DatabaseDialog.java:60)
at org.pentaho.di.ui.spoon.delegates.SpoonDBDelegate.newConnection(SpoonDBDelegate.java:494)
at org.pentaho.di.ui.spoon.delegates.SpoonDBDelegate.newConnection(SpoonDBDelegate.java:481)
at org.pentaho.di.ui.spoon.Spoon.doubleClickedInTree(Spoon.java:3092)
at org.pentaho.di.ui.spoon.Spoon.doubleClickedInTree(Spoon.java:3062)
at org.pentaho.di.ui.spoon.Spoon.access$2200(Spoon.java:361)
at org.pentaho.di.ui.spoon.Spoon$27.widgetDefaultSelected(Spoon.java:6148)
at org.pentaho.di.ui.spoon.Spoon.readAndDispatch(Spoon.java:1366)
at org.pentaho.di.ui.spoon.Spoon.waitForDispose(Spoon.java:7984)
at org.pentaho.di.ui.spoon.Spoon.start(Spoon.java:9245)
at org.pentaho.di.ui.spoon.Spoon.main(Spoon.java:692)
at org.pentaho.commons.launcher.Launcher.main(Launcher.java:92)
Caused by: org.pentaho.di.core.exception.KettleDatabaseException:
at org.pentaho.di.core.database.Database.connectUsingClass(Database.java:515)
at org.pentaho.di.core.database.Database.normalConnect(Database.java:456)
... 48 more
Caused by: java.lang.ClassNotFoundException: sun.jdbc.odbc.JdbcOdbcDriver
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.pentaho.di.core.database.Database.connectUsingClass(Database.java:490)
... 49 more
Custom URL :null
Custom Driver Class:null
Please Suggest What I Am Missing...
Thanks in Adv.
-Shashank
Greetings,
access : ODBC
... 48 more
... 49 more
Custom URL :null
Thanks in Adv.
-Shashank
