[Progress Communities] [Progress OpenEdge ABL] Forum Post: Strange problem related to streams and break by totals.
  • Thread starter Joseph Kreifels
  • Start date
Joseph Kreifels
Why is it that using a total will cause Progress to process the code, even though it doesn't meet the condition? Code: def var yesno as log no-undo. def stream s_file. def temp-table t-table field name as char field age as int. create t-table. assign name = "Bob" age = 44. if yesno then output stream s_file to terminal. for each t-table break by name: if yesno then display stream s_file age(total by name) with frame a. end. This throws the error ** Attempt to write to closed stream s_file. (1387) if I replace age(total by name) with just age or remove it entirely, things work okay. This is just a simplistic isolated example of a problem I am having. Don't think too much into why someone would want to total age. :/
