gus bjorklund
> On Aug 16, 2019, at 2:56 AM, fiservarvind wrote: > > Do we have any tools which can tell us your data is encrypted or not you can use the "strings" command to extract all readable the text from a data extent. then encrypt the data and run the strings command again. this is not an exhaustive test, but it easy to do. you can also use the "od" command to dump selected portions a data extent and compare before and after.
