[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: SYSTEM ERROR: Schema cache key, xref, or key field count incorrect. (996)
Rob Fitzpatrick
I've never seen a (996) error when building indexes. There are a couple of KB articles related to this error, one about adding a default index and the other is specific to Progress 9.x. Neither one is applicable to your situation so I'd suggest opening a case with TS. On an unrelated note, I'd also suggest adding -pfactor 80 to your parameters as the default of 100 is too high. It will result in a lot of post-build block splits as you do creates and updates.
