jquerijero
[quote user="ithrees"] Dears, I have a case where I have to write an excel file with the data from a procedure so the excel file will have a main header, column header and column data. As I am looking for the most efficient and simplest way to get this done, I am looking for your great suggestion for the same. ** this is not about writing csv file Thank You in advance, Ithrees [/quote] Not sure why last post is not showing. Since you seem to be going the Windows route, have you looked at the Infragistics.Document.Excel namespace? It's part of the Infragistics component that comes with PDSOE installation. You can use it to create an Excel file on-the-fly. UltraGrid also has a corresponding Excel export feature, which can export the current view of the grid.
