[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Pro2 multi-tenant OpenEdge db replication using CDC
Satya Prasad
-Yes. it is NOT possible to use CDC feature to replicate multi-tenant database changes. This is because of "_Cdc-Change-Tracking" table is not a multi-tenant table. This is the limitation on the database side. -Yes, use pro2 replication triggers against multi-tenant database to replicate the table changes. Thanks, Satya
